Bolt-On Exhausts For Athena 70cc
Which exhausts are direct bolt ons for the Athena 70cc kit?
Re: Bolt-On Exhausts For Athena 70cc
everything but simonini and 8p. Simo will fit, you just need to cut some fins.
Technigas Next, Proma GP, Proma CC, Tecno Boss, Tecno Estoril...these will all mount directly to the Athena exhaust port, but may require other modifications to clear specific parts depending on the moped model?
i have a homo 6p i will sell ya
athena + estoril = fast
When mounting an Estoril to an Athena kit, will that possible require modifications when used on a Magnum?
Hey I run the non reed version of thhat kit on the maxi and I bi-tubro bolts up like butter
i have an estoril and athena with the reed on my maxi. i had to drill the holes a little bit bigger on the exhaust flange.
Where do you guys get the different versions of this kit...or do you just remove the reeds yourself? Is there only one version of the Estoril...who carries this part that has it in stock?
Really appreciate the help....thanks.
theres 2 athena kits one reed one non reed.
one estoril version for puch,
mwh had the dmp which is the same as the estoril but it has a carbon fiber silenscer.
MWH has the athena kit and DMP pipe and the carb you need thats where i got my kit, it flys!
