Re: qt50 oil pump removal
Brandon Yates /
So do I take just the gear out of the pump or the corresponding gear coming from the case too. If I'm getting rid of the pump I'm going to make a plug plate at work. So I think I need it gone. I want a clean look, not a non working pump sitting there. So is the gear coming from the case hard to get out? Or will it be easy with the side plate removed?
