Re: qt50 oil pump removal
1.) take the white plastic cover off the oil pump.
2.) remove the oil line going from the pump the the carb.
2.) remove the two or three screws that hold the oil pump on the motor
3.) pull out the oil pump(it will take a little twisting as there's an o ring to seal it)
4.) you can now either:
A) plug the hole left by the oil pump with a plug of some sort
B) remove the gear off the oil pump, then reinstall the pump to seal the hole.
