Tomos sells A35 stator and mag/rotor for 120$ the coil is 50$ regulator 30$...200$...not to bad for 12v bright lites that hardly ever burn out...ability to run 31 tooth front sprocket...and timing you can adjust...someone needs to find that post way back about using a car timing light to set timing(limited computer skills) ...Im to tired to go through it now-sleepy- but I will if needed...if you find it post it on this thread...That Arciero was paced at 62mph today on a wide open PCH blast..Flat ground....66+ on some of the dips...not possible without A35 igniton setup 21mm carb and 31-20 gear on a 17"wheel...50cc A35(modified) stock cylinder with over 3.000 hard miles on it...funnest bike
