i know i should have a 16mm intake if i have a 16mm carb but i have a 14mm intake.
i could bore out the part that goes into the carb not to hard.
but i was thinking. if i bore the diagonal piece will it widen it so much that i get airleaks on both sides? and they way the opening is, is it worth it to drill the diagonal piece?
will i get any more gains if i do bore the diagonal piece out?
how much will i not get out of the carb due to the 14mm diagonal piece
note: i know it is a 12mm intake but i measured and it read 14mm
