malossi 21mm carb kit/Honda Hobbit
Anyone used the malossi 21mm carb kit for the hobbit? How does it do on the 50cc motor?
Re: malossi 21mm carb kit/Honda Hobbit
NO..
No as in you have not or No as in Don't do it.
NO, as in, YOU WILL NEED A KIT. And a pipe too. One thing you can do, that I just realized as I was putting on the 21 PHBG, is take out the choke from your carb. If you don't need to choke your bike to start it you would get a lot better flow if you took out the plate that chokes your bike and the support it is screwed into. About a quarter of the room in the throat of the carb is taken up by that stuff. You'll then have a big hole in the top of your carb though, but you can easily patch that with some JB Weld (if you don't ever want to have a choke) or some liquid steel (if you want to some day pop it out).
