Pulling a clutch
Wheel puller isnt working... Is there a specialized tool for an E50 2 shoe?
Re: Pulling a clutch
yes
try 1977 or mwh
Make your own. You can get a puller that is close from any parts store and put the correct pitch bolts in it. I use one from Auto Zone. Doesn't work as nice as a made for it puller, but it gets the job done.
i used a generic wheel puller. don't be afraid to put a little muscle into it.
i just used a longer bar for some easy leverage. i don't think you'll have a problem ruining your crank because it's made out of a lot harder material than the bit for the puller. mine gave some resistance and then popped off real hard. could be you just need to get more aggressive.
