hills
hey guys, i was wondering if there was some small adjustments to get my moped to be stronger uphill. 78 hobbit
Re: hills
Steve Hills?
Re: hills
so almost posted that.
Re: hills
Raymond Rexroad /
What is your setup? All stock?
What speed are you going uphill? 5, 10, 15, or how many MPH?
What is your variator position when climbing the hills? Is it fully shifted, about half, or what. I'm asking because I may recommend that you try lighter variator weights. This would keep your Hobbit "in low gear" longer, as you accelerate, and would allow the engine to "rev up" sooner as you slow down.
Re: hills
less restrictive intake and then upjet, also clean the carbon outta your exhaust
Re: hills
Raymond Rexroad /
less restrictive intake???
I've never seen a one for a Hobbit.
The venturi is 12mm, the carb "throat" is about 15mm, and the intake manifold inlet is also 15mm.
Please explain your comment . . . .
