Need Help..Advice Please..Puch
okay so here is what i'm running
Magnum with E50
65 MetraKit
Hi Comp Head
Bullet Exhaust
20mm PHBG with 85 main jet and 50 idle jet
19mm intake
stock gearing...i think 40-16 or something like that
it kinda slow off the line...bogs a little bit but not too bad. i want better performance off the line. i know changing gearing will help... but im trying not to cut too much off of my top speed. would jetting help me out at all? please im open to all suggestion. i am also thinking of putting a 3 shoe clutch on that bitch.
please let me know what you guys run and jetting and what not. thanks guys and girls
Re: Need Help..Advice Please..Puch
Jetting seems a little high. Was running a 72 and ripping on my 15 and after my soft seize switched up to an 82 and now suck off the line. I thing you could stand to go down a couple jet sizes.
change your pipe, advance your timing, tune your clutcn and then retune your carb.
I don't think the pipe is the issue cause that's what I'm running but you could be different. I agree with everything else.
How are your plug chops looking?
