70 cc polini kit for garelli
Hi all, I just picked up a Garelli and I was wondering if I could get anyone who has put a polini 70cc kit on one to give me some input.
- Did you have any trouble putting it on?
- what would be a nice pipe to use with it?
- Did you use the 14/12 dellorto and upjet? if so to what jet#, if not what carb did you use?
Thanks in advance. - Joe
Re: 70 cc polini kit for garelli
þλ†Я¡¢k §¡§ΩИ /
thanks
what garelli did you get? does it have the certical or the horizontal engine? josh at 1977 let me know that the pollini 70cc kits will only mount up to the horizontal engines. good to know, so you dont wast 200 dollars on nothing.
apparently i wrote that last post when i was five. what does this spell check button do?
It's a Gran Sport step through. Someone rattle can painted it black at one piont so it is a real overhaul project. I just want to get the motor running first, and then strip the whole thing down and make it look good.
Good to know about the kit only fitting the horizontal type. Mine has that so if I do decide to spend that much it would fit. -Joe
