if you rev it up on the stand then hold down the back brake stop the wheel and give it gas but keep the wheel locked what happens?
does it still die or barely pull when u give it gas or does the motor try to struggle up into rpms by spinning the clutch even tho the wheel is locked in place and really seems like it has power.
if the motor has power the issue is idling or ur clutch settings, try adjusting the throttle slide higher so it idles higher.
if the motor has no power the issue is in tuning and or there are air leaks (not the exhaust leak unless its massive)
