Re: no spark after high tention coil!!!
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
this is dean this time
tony has pretty much swapped out the entire electrical system, a few parts more than once. he cleaned his points and timed it and got great spark off the stator, but super super weak spark from the plug wire (no cap/plug) through the hi-ten coil.
do you think the new condenser might be bad too? great spark on it's own, but after putting it through the hi-ten coil (resistance) weak spark, as in maybe leaking through the condenser?
