no spark after high tention coil!!!
I have very very low spark coming out of my coil. I have replaced everything condenser etc...but no good spark. Theres great spark leading up to the coil, but after that no . What could be the problem?
Help help help
Tony
Re: no spark after high tention coil!!!
Am I being an ass to ask whether you tried a different coil? Condensors can be bad right off the shelf new
Snord, I tried three of them but have the same problem
If the cap and lead are good too then youmight try another condensor. Any partial grounds?
this is dean this time
tony has pretty much swapped out the entire electrical system, a few parts more than once. he cleaned his points and timed it and got great spark off the stator, but super super weak spark from the plug wire (no cap/plug) through the hi-ten coil.
do you think the new condenser might be bad too? great spark on it's own, but after putting it through the hi-ten coil (resistance) weak spark, as in maybe leaking through the condenser?
Well I guess 3 coils can't lie. You might want to buy a handfull of those $7 external condensors for times like these. Consors can fail from a parial short, full short or an open
fixed!!!!!!!!!!!!!! thanks to Brenden mother fucking barrens.
and how
Points weren't opening.
