Re: Holy hell with a kit
Kansas John /
If you've got consistent spark, and the cylinder is wet after you try to start several times then pop the head, then try unscrewing the spark plug, spraying a little starting fluid in the cylinder, replacing the plug, and giving it a try. If that doesn't work, I'd look at timing.
