Re: Bing 15mm Intake...
The 2 speeds have intakes which are taller to accommodate the carb because the motor has casing in the way. The earlier puch cylinders have rectangular intake ports, or you could just open yours up to match the intake. You are going to need a spacer to make that manifold work. I think mopedshop sells one, but its not very cheap.
