1977 Mopeds sent me a 15mm intake for my Maxi and I'm wondering if they sent me the wrong piece? It fits into the neck of the carb fine and the bolt match-up to the engine block is correct - however, the carb sits way to low and is resting on the engine block instead of being positioned with proper clearance. Curiously, the bottom flange (inside of intake tube) was machined to a rectangular configuration instead of matching the intake port (which is round). Additionally, this position will not allow me to mount the stock air cleaner back into it's hole on the frame.
I have a 1979 Puch Maxi II. The carb has already been upgraded to Bing 15mm.
Thanks for your help!
Steve.
