Top End Mystery Sounds
Hi,
When I pull full throttle, my Puch used to bog down (engine sound dropped & speed... four stroking, I believe).
I adjusted the needle and I can go full throttle now. Though now I have a whole new sound to deal with. Now when going full throttle, I hear this loud clanking sound. Kind of high pitch... also, I can feel my bike slowing down. It almost seems that the piston can't keep up or something. Kind of the same sound you hear when you're hauling ass & just let off the throttle..
When I let on and off the gas, the sound will go away (smooth ride).. but not always.
Is this a sign of it running too lean on the top end?
I have a Puch MKII sport (2 speed). Proma GP pipe & high air filter.
12mm bing w 58 jet. My neelde is in the 2nd or 3rd position... forgot which.
Thanks Folks.
Re: Top End Mystery Sounds
Yup,apparently that's a lean spot in your powerband.Don't run it hard up there until someone with more experience can help you,all I can do is say be careful about revving that high.
Easy way to tell, put a larger mainjet in and see if the plug chop is darker. I generally try to upjet until it 4strokes, then go down one or two sizes to make sure I'm not too lean.
osprey of Dee'z loinz /
what gearing are you running?
Check to make sure you are not riding Dutch backwards up a hill, it might be the wood shoes clapping together at high speed! ;-)
The needle is only for 1/4 to 3/4 throttle. The jet is for full throttle the high pitched noise is the piston scraping the cylinder? Or maybe an intake that whistles like mine. I say upjet.
Dude that was fix!... my foot got slammed to the ground by this huge sloppy pancake.
