Re: Air Filter Review! New Champ Revealed!
Confuser - /
i didn't try out that big red malossi, but i can tell you that it wouldn't have fit. that thing is huge!
the 90 degree malossi would probably be extra rad if it came with the same black filter as this one does. and it looks like it could based on that picture from 77 up there, but i've only seen it with the red.
the black material is probably as close as you can get to not having an air filter while keeping out the bad stuff.
when it's not compressed, like before you tighten it down, you can basically see through it. crazy flow.
aesthetically pleasing and performance ready. yep.
