if i run this filter break> will the jets that come with it fit in my a35 carb?
will the idle jet be nessesary?
somebody will probably pipe in about what kind of carb the a55's use, but your a35 i would guess is a dellorto 14.12 sha, and that air pod probably wont fit, and you only have a main jet, no idle jet. Look for the high flow air box..it's a black plastic cover that fits nicely over yr carb.
it is a 14.12 sha.
why wont it fit?
Because you just said you want it to fit the carb on your A35, that is an upgrade kit for the A55 motor. They don't use 14.12 SHA carbs, the A55 uses a PHVA carb or something. Your SHA carb doesn't have an idle jet, just a main jet.
i know it only has a main jet!
well the main jet fit?
All Dellorto carbs use the same jets.
thank you. anyone know what MAIN jet it comes with (#?)
Pop it out and see!
Then just spend $3 on a new jet....
no they dont!
PHVA uses 6mm ones, the ones in that kit, they wont work on a SHA!
bleh~SABAT!
those 14-12 sha's are can be stubborn. take the screen out and in. you'll learn alot real fast.
