V1 Kit?
Does anyone know anything about this V1 performance kit? The image is linked, and the specs are this:
"special alloy/chrome cylinder kit DR bore 41mm with head and other accessories"
Re: V1 Kit?
Linked image....whoops.
Re: V1 Kit?
lee's anus is leefungchowOG /
what is that like 55cc? not for use with minarelli fan. will fit on a v1
Re: V1 Kit?
mark from the hells satans has one, i really like it. runs well, not super fast, low 40's.
Re: V1 Kit?
but does it use the fan?
Re: V1 Kit?
no. it doesn't need to since the fins face the other way.
Re: V1 Kit?
This kit has a dyke top ring just to let you.. has good mid range with the right pipe. The exhaust port is very small alot of metal to remove just when porting a pipe to the cylinder.. the intake should get a 15mm phbg. No single jet carbie.
Re: V1 Kit?
the picture is for the reed valve minarelli not the V1. I have this motor on my safari. I think the motor is the VL1. Find a good polini or the 86cc kit. However if you have the reed valve motor then this is the kit you need or there is another out there about 46mm
