Does anyone know anything about this V1 performance kit? The image is linked, and the specs are this:
"special alloy/chrome cylinder kit DR bore 41mm with head and other accessories"
what is that like 55cc? not for use with minarelli fan. will fit on a v1
mark from the hells satans has one, i really like it. runs well, not super fast, low 40's.
but does it use the fan?
no. it doesn't need to since the fins face the other way.
This kit has a dyke top ring just to let you.. has good mid range with the right pipe. The exhaust port is very small alot of metal to remove just when porting a pipe to the cylinder.. the intake should get a 15mm phbg. No single jet carbie.
the picture is for the reed valve minarelli not the V1. I have this motor on my safari. I think the motor is the VL1. Find a good polini or the 86cc kit. However if you have the reed valve motor then this is the kit you need or there is another out there about 46mm
