Re: Dummy bearings, AV7/10 crank fitting??'s
Jesse Stephenson /
dude, seriously, heat is the way to do this. A press fit is usually 5 thousands over. Which means the inner is larger than the outer by a small amount. The steel will change that much if you heat it by 3-400 hundred degrees. Why hit things with hammers if you don't have to.
