Re: Dummy bearings, AV7/10 crank fitting??'s
Crackstar X /
See, I would rather not half ass it, with my polini cases and doppler crank, I have noticed a quite a bit of difference in the depth of the holes for the bearings in the case and the actual thickness of the bearings. I f I were to drop one side on and have that bearing bottom out in the case the crank may be off center, in reference to the con-rod, when I place the other case half on. Thats all Im checking into..
but is it everyone who builds these just drops the halves on/together, no blow ups or ruined bearings/parts/kits with this method?s
