What are you guys using for intakes on these beasts? I've been having trouble hunting down 19mm intakes for the phgb.
I dont know what others are using, but I made my own.
hacked puch header.
puch exhaust header cut and welded.
V1 header works the same as well.
it would help to know your setup.
65cc metra kitted e50.
treatshq has one.
is your phbg a clamp on? If so, treats has it. If not, build one with some handle bars or a header, then use a rubber coupler and hose clamps.
might have to shave the base down a little so you can put the nuts onto the intake studs.
