lacking performance, what to try
1hp maxi with 2hp cylinder head, 15mm bing and intake, hi airflow filter, tecno bullet, 70 jet chopped and tan, sava mc11s, carbs clean, ports clean, running 50:!... doesn't want to seem to go past 25-27mph. seems to run fine otherwise. what should i check?
Re: lacking performance, what to try
everything...
but start with the timing and points....correct gap....
Check your gearing
