What are the effects of putting a high compression head on my e50. powerband change? or is my engine going to get hotter?
The header is part of the exhaust. The head is the head. HC heads are my preference. There's a slight improvement in power. Don't worry about it getting hot. Get a colder plug if anything. If you have a stock cylinder with a HC head, try an NGK B6HS or Champion L86C (Auto Zone can look up the other brands' equivalents for you).
I usually refer to the header as an exhaaust manifold, but your right. I kno the cooling fins are way bigger on this head and thought it might run hot.
