Morini M1 65cc kit
Has anyone tried one yet? I just got mine and it looks like the piston skirts may need to be widened a little to match cleanly. Otherwise, everything else looks nice.
Since I couldn't come up with an option for an intake or upgraded reed kit, I guess I'll have to bore out my intake and bend my reedstops out a bit.
Hopefully that and a Dellorto 16:16 and BOSS pipe will net me some speed:)
Re: Morini M1 65cc kit
here a tip so that you dont fuck that nice kit..
USE A FILE...ONLY!
File into the piston only dont go both ways use a file that cuts one way only. Good luck and yes remove that shit.
Those transfers are huge compared to the stock cylinder, good luck making a case match there.
You can cut your own reed material, malossi sells them in sheets and I'm sure you could find other brands that do the same thing.
I haven't even had a look at the case yet, so I have no idea what I'm in for there.
Thanks for the tips about filing, I would have gone straight for the dremel. Maybe I'll hit Sears tomorrow and pick up a new file. I'm kind of lacking in that department. I need to get a drill bit bigger than a 1/2" for my intake anyway.
NICE I will be waiting to hear of your results and pics of filed down piston and transfer work because I want to get one of those for myself . from 1977 mopeds right with or without gaskets
þλ†Я¡¢k §¡§ΩИ /
nobody ever seems to respond to my post if i start my own thread. do you guys know if m01 bottom end parts are interchangable with m1?
ケサムツグ チノカコサ /
What parts? Flywheel? Bearings? The cases are completely different, MO1 being piston port and M1 being case inducted reed valve. What parts do you want to swap?
þλ†Я¡¢k §¡§ΩИ /
what parts can i swap?
You can swap: main gear+clutch+magneto+bearings+all internal parts but be warned...the M1 uses a shim on the main gear _inside_ the case and the M01 doesn't. I don't know about the cranks yet though I'll compare them later on tomorrow I'm bone tired.
þλ†Я¡¢k §¡§ΩИ /
thanks for the info..
