ok i have a new crank with new seals and bearings. should the crank spin freely?
with the case apart it spins fine but when i put the case on with the case screws tight ,the crank is very hard to spin.if i loosen the case screws then it turns easy.
i am thinking that the seals are new so its grabing onto the crank.
