anyone hear of anything negative of this kit...
is there an easier, more reliable kit?
expected top speed with a 22 tooth rear?
GO to kpodj.com. I have heard only good things about it, just make sure you religiously follow some of these guys instructions on the breakin.
"the dj house":http://www.thedjhouse.com/item/100392 is $5 cheaper! :P
what are some of the break in instructions?
when you sieze does the ped stop moving all together?
Got one runs great. I did nothing to my engine (port match etc,) put it straight on with a homoet and 16mm dellorto and its showing 52 mph with a digital bike speedo. My setup is good to me
they are installed on thousands of tomos out there.
Reliable if you run it correctly.
big power gains if you got the proper setup + porting.
