How much money is in your engine
Well im sitting around pondering how to spend my stimulus check. Ive been adding numbers, and once all is said and done and i have my engine built ill have over 500 dollars into my e50. thats the speed kit, carb, clutch, crankshaft, all new bearing and seals. How much money have you guys put into your engines???
Re: How much money is in your engine
there was a fistful of pennies in my gas tank for awhile
fish_SHARK /
i usually go through about 3.40 a week or so
probally scarry to think about but what the hell...
Za50 motor - free
80Metra - 200
welding to fit motor - 35
21mm phbg - 75
Custom intake - 40
air filter - 15
motomatic 8p - 180?
bearing and seals - 60
Hey thats not all that bad, granted the stock con-rod only lasted me 1000 miles and cost me a piston, so add in a new piston a roller rod and my machinest fees for pressing it in.
over $600 :(
are you guys nuts ??? I can see wanting to go a little faster on your ped but 600 bucks, I dont think I have that much into all 5 of my bikes
my gf has a free moped with a free 75cc polini kit, free 14 14 carb, free mc2 tires, free engine tuning, free engine work, free 'big head' and free new clutch cable.
i suppose free should be in quotes since she does let me touch her no no places lol.
Well lets go and add it all up, even though I dont wanna see it in black and white.
Vespa Grande: $250
13.13 Dellorto: $60
Redfilter: $15
Race crank, Malossi 64cc, high compression head: $210
Leo Vinci (if we're counting exhausts): $90
Current setup:
ZA50: $40
Korado Cylinder: free
19 Racing PHBG: S110
Air filter: $15
magX bendy intake: free
Simonini: $305
So what, almost $165? Thats not bad
My other motor:
kickstart e50: free
top crank: $110
Bearings/seals: $30
Polini: free (used)
Malossi 4 petal reeds: $50
High-Comp head: $30
Motomatic N8p: $140ish
PAz clutch springs: $15
Thats $375 and did almost 60, or did with different gearing. Currently down though.
Both are assuming the Magnum X was free, but it wasn't.
60 BIG BORE kit 329 plus 10 fort fgrt
7-jets later 21 dollars
40 miles per hr ,pricelsess.
looking at about six hundred dollars on my floor right now.. :\ seems like a lot, but it took me a while to gather all the parts, so it works out to only about $100 a month..not bad.
carb - $65
kit - $150
other kit - $165
crank - $95
bearings and seals - $30
and I guess if we're counting clutches and pipes then
variator - $90
pipe - $100
Polini 70 kit import from italy $200
malossi 4 pedal reed intake $45
20mm PHBG $90
Malossi CDI $200
Doppler Pipe $180
uhh
715 i guess....
You make money, you spend money.
You only live once, so spend your hard earned cash in a way that truly puts a smile on your face.
You cannot put a price on happiness.
With that said....
Polini = $200
Intake = $30
Carb = $60
Pipe = $120
All new seals and bearings = $60
Eh, I dont care. Mopeds is what I love and do not mind spending money on it....
hella euros :D
just motor, right?
yeah, over $600.
hey, i'm obsessed. the bike was free! i'm still under the price of a new tomos, and the thing might kill me when it's done.. so yeah, totally worth.
i guess i dont feel so bad now, i didnt even think of the pipe though that puts me over 600. Im gonna try and buy parts one at a time though, to even it out some
Engine – $100 (includes shipping) + other engine…2 e50’s
Gaskets- $20
Sealant- $6 (2 tubes)
70cc TCCD- $109
Circlips- $2
Proma GP- $80
Stock crank- free
External coil- $38
Bing carb 12mm- free …bored out to 14.9mm –some work but free
Puch high flow air filter- $20
Jets- $12
spark plug- $3
So about $390 and that is with basically 2 working motors and the
other motor just needs a carb… and frame...But I love my
moped!!!! And eventually better parts to replace old ones.
so fucking much.
Maxi, 25$
Korrado Mags, Free
80cc Gila. 250$
24mm Mikuni, 80$
Intake, 2$(Jb Weld)
Homoet 8p 150$
Tiny tach 30$
Airbox 1$ (PBR Can)
Pantie hose 79
not too much.
FAG bearings $30
malossi 62 $120
del 15 $78
15 intake $20
other random shit $40 (there was a lot of random shit)
$288. Not bad, but im getting there. soon to be:
G3 $180
Varplus $75
which would make it $543
i just sell other mopeds to support my moped habbit!
I dont even want to think about this, but why not.
My magnum has had two different bottom ends in in, 2 new cranks, 4 different kits, 3 different carbs, and a couple new pistons before I finally got to the point i was happy with, but current set up.
80 metra - 220
Mikuni flatslide - 105
simonini - 130
Custom intake - 50 (thanks jeff)
DMP crank - 110
Pipe welding - 20 (thanks again jeff)
Bearing and seals -40?
Thats $625. Plus lots of timing porting the cylinder and matching the cases.
Now my Gila set-up that I am working on you can add atleast $300 to.
I'm dumb, and sad that I thought about this.
13.13 carb 55
redfilter 15
DR racing kit 110
Milled head Free
sloppy porting free :)
110 for exhuast not much at all
i need a frame brace
no money in upgrades yet, but I was really hoping to keep it under like 250-300 for exhaust, kit, and some other odds and ends... damn hope it doesn't end up costing $500.... especially since my parents still claim me as a dependent so no stimulus check for me... crap.
Great thread...
Full of agony and sorrow.
Man, you guys can't even compete with a Moby on dollars spent.
Parma Crank - 86
Parma Kit - 200
Ninja G3 pipe - 125
Doppler Clutch Pulley - 300
Intake - 20
Bearings and Seals - 30
Dellorto PHBG 19mm - 100
Mallosi Variplus - 100
Malossi CDI - 200
TOTAL = $1161
Moral of the story, Motobecane is a long and windy road into assured debt. And I can still only go 55-60mph (Maybe faster now that I have on a smaller back sprocket)
let's see
metrakit - $153
dmp crank (stuffed) - $110
19mm phbg carb - $90
racing slicks - $45
uni air filter - $15
cables - $30
jets - $30
so about $475, all told
. . . oh yeah, + $75 for the bullet pipe, so $550
my $600 was only the engine. that doesn't count the cdi, pipe, variator, intake or carb, or the transmission gears. yeesh.
damn what engine do you have
malossi crank case, malossi crank, pinasco top end and quality japanese bearings. doesn't sound like much, but that kit was pretty spendy, and i had to import it.
