This board has a search function.
Story short: it can be done, jetting your carb right will be the biggest issue. Air/fuel ration for booze is much higher than for gas, around 8:1, it won't make you go any faster, alcohol is only 90% the effieciency of gas. It''l probably run alright for a while until the rings wear out and you start getting massive blow by
