about the question mark
On your drawing, the wire from the battery negative terminal goes to a question mark. The battery negative needs to be connected to ground.
battery?
Even the smallest lead acid 12V battery can give you 6 amperes of current. It is my opinion that you can use the smallest (in physical size) battery you can find.
