Re: electrical junkies!
Raymond Rexroad /
the green that you have labled to white wire from engine do you mean the yellow?
If you look at the picture provided, there is only one wire that has the words "to white wire from engine" next to it. The wire it is pointing to looks to be green.
No offense here - but are you even looking at the pic? I can't make it any clearer.
P.S. You've consistenty used the phrase "CDI", and I've used it too, so you could follow along, but according to an A35 manual, your Tomos doesn't have CDI - just a plain points-type ignition. The part you have labelled CDI is actually the ignition coil. It doesn't change the wiring you've drawn out, but when communicating with others, it will be helpful to call it what it is.
  electrical junkies!Topic by: sam sam 05/18/08 04:41PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 06:06PM
  Re: electrical junkies!Re: sam sam 05/18/08 07:10PM
  Re: electrical junkies!Re: sam sam 05/18/08 07:55PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:02PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:03PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:04PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:06PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:09PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:15PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:16PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:18PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:21PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:27PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:27PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:30PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:30PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 08:34PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:51PM
  Re: electrical junkies!Re: sam sam 05/18/08 08:55PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 09:43PM
  Re: electrical junkies!Re: sam sam 05/18/08 09:46PM
  Re: electrical junkies!Re: sam sam 05/18/08 09:48PM
  Re: electrical junkies!Re: Raymond Rexroad Raymond Rexroad 05/18/08 09:55PM
  Re: electrical junkies!Re: sam sam 05/18/08 10:19PM
  Re: electrical junkies!Re: sam sam 05/18/08 10:23PM
