Re: super fast idle on start
imonfire /
did the carb cleaner trick, found a leak next to the intake manifold.
took the top end apart again.....doubled up the gaskets on the intake manifold, tightened the bolts a ton. kicked it over, and its still running WOT. This time i cant seem to find a leak with the carb cleaner around the intake or carb, any ideas?
