Re: How far can you tilt your carb?
Acutally, the engine case is not touching the carb. I ground way a bunch of material to make sure that wouldn't happen.
It's the damn frame in the way at the top of the carb...
It seems to run strong though and have no idleing or running issues other than what I believe is MAD piston slap making a ton of noise...
Check out my other post about it...
https://www.mopedarmy.com/forums/discuss/7/95995/95995/
I'm freakin' desperate to find out what the noise is....
