Re: How far can you tilt your carb?
Thanks for the input.
I'm not sure the intake can be rotated 90 degrees as it is oblong, and not perfectly square. I'll take another look though.
I started it up, and it seemed to run well for the couple minutes I ran it.
I took the Techno Estoril off my Lazer and put it on the pinto until my Simonini comes in probably on Monday.
The biggest problem right now is that there is a metal pinging sound. I think the piston is barely touching the head and causeing the metal clanging sound.
I'm gonna install a second base gasket and hope for the best tomorrow.
I'll let you know.
Thanks again,
Justin
