K&N air filter
Does anyone no where i can find a K&N filter for a tomos a35.
Re: K&N air filter
most autoparts stores could order it, or just online from the k&n website.
Re: K&N air filter
Would a k&n filter for an a55 fit the a35
Re: K&N air filter
no, the a55's have a different model dellorto. You can use a k&n model number RC-0790. It will fit over the boot part of your stock air box. Or you can get a larger diameter one that will clamp on to the entire outside diameter of the carb itself which i think is 33mm or 35mm. Im not sure what model, but you can check K&N website to find one where the filters inner diameter will fit. Just dont forget to upjet accordingly
