65 Metra Piston and Cylinder scoring
DAMN IT, I posted before but nobody responded. Here are some pictures of the piston and cylinder that I took after I pulled them off. Let me know what you think.
Re: 65 Metra Piston and Cylinder scoring
piston
looks like an exhaust-side soft-seize. clean it up with a little very fine sandpaper, you should be fine.
When Cleaning this up, what direction should I move the sandpaper? Im planning on installing this thing again and running it tonight. Shit, I KNEW I soft seized. I told the cupertino guys on the first ride.
Oh, what size grit should I clean this bitch up with? I have 400grit wet/dry. Is that fine enough or I am I needing to go into the 1000 grits?
