its a matter of preference. technically if you reaaaaally wanted a cable choke, you'd need to rig a lever up at the handlebars so you could adjust the choke via the cable. cable chokes can be nice, so you can choke while riding if need be and not have to kill yourself reaching the lever, but they can be a nuissance to install as well.
otherwise, go with the click choke. it chokes in the same way that your bing does (well, pretty much), in that you push down a lever on the carb and it doesnt "click" off until you snap the throttle.
