Whats Better?
I just bought a 70cc speed kit but want to know whats better A rear sprocket of front sprocket
Re: Whats Better?
huh?
Re: Whats Better?
Like should i change the front sprocket or the rear or leave them both stock
Re: Whats Better?
depends. what do you hope to achieve?
Re: Whats Better?
And what's your current gearing?
Re: Whats Better?
Excessively small sprockets will rob power. But the answer really depends on what you can buy/make. What will fit. Chain length can be an issue as well.
Is the kit on, tuned, and broken in?
Re: Whats Better?
Not yet and i am just trying to get more power
Re: Whats Better?
then keep stock or get a bigger rear or smaller front...
either will slow you down but make you pull out fast
when playing with sprockets you loss on top and gain bottom or gain on top and loss on bottom end.
with the kit if i were you i would keep the gearing stock if i wanted bottom... to go lower is just over kill inless you want to go slow (as hell) but quickly
