Re: best way to speed up a ciao single speed ??
Graham Motzing /
you can cut the crank/port the case for free, but its pretty hard to get it apart and back together without wrecking the bearings. the stock SHA dellorto can be drilled out, the stock intake can be drilled out, and there are a lot of pipes floating around for ciaos these days.
you can also put a smaller pulley on the back.
