Re: rear sprocket for Sachs
educatetheyouth /
hi fellow Mopediphile! I've read somewhere in another post that the Sachs rear wheel is compatible with a Motobecane rear wheel. With this conversion you gain sealed bearings and a 36 tooth sprocket(or 32, i cannot recall at the moment) and is supposedly compatible with the rear pedal brake. I myself have been looking for a different rear sprocket. Did you happen to check out Mopedshop.com? they currently have a 12 tooth front sprocket for sale(OEM is 11 tooth) . If you find out anything lemme know thanks
danielnguyen2012@hotmail.com
