hey does anyone know what my options are as far as a rear sprocket goes? are there any from other bikes that might be compatible with a sachs g3? the only sprocket ive found so far is a 44th but im looking to get a 42...
hi fellow Mopediphile! I've read somewhere in another post that the Sachs rear wheel is compatible with a Motobecane rear wheel. With this conversion you gain sealed bearings and a 36 tooth sprocket(or 32, i cannot recall at the moment) and is supposedly compatible with the rear pedal brake. I myself have been looking for a different rear sprocket. Did you happen to check out Mopedshop.com? they currently have a 12 tooth front sprocket for sale(OEM is 11 tooth) . If you find out anything lemme know thanks
danielnguyen2012@hotmail.com
try handybikes
Check your sprocket. Should have a number on it. If its a Z- then a number. Then it takes the Z sprockets like my Seville. You can get them in all kinds of sizes. Ask BJ at Handybikes.
Cool man ill check right now. Good info
thanks dudes!
i found this on mopedshop-
Rear sprocket for Italian wheels 42 teeth - 42.5mm center hole - 4 7mm mounting bolts - 66mm bolt hole circle - flat sprocket - no offset. New old Stock OE for Safari mopeds.
think maybe that will work on my sachs g3? i couldnt find any letters on it so i cant tell what type of sprocket compatability i may have...
Thats the one. Its a Z-42.
cool thanks for the info! =)
