Re: how fast is your ped?
doppelkolben /
"95+mph.lol i got a wildfire 150cc moped"
Wow, annoying. Very annoying, but it puts things in perspective.
Check this out.
It's a script that calculates the air drag of a bicyclist based
on speed. The "Weight" field doesn't do anything - if you put in
"0" for wind speed and grade, you can use this to find out how
much energy it takes to overcome the force of wind resistance
(just wind resistance) to get to a certain speed with a front
surface area approximately equivalent to that of a bicyclist
(which will actually be smaller than that of a moped - this utility
will spit out a number on the low side).
So, let's try it - Tommy went 70mph. According to the widget, it
would require 4031 watts to maintain that speed against wind
resistance. That's a little more than five horsepower.
It does take some power to overcome inertia, bearing
resistance, and simple rolling resistance, so he would have
needed an engine that did even better than five horsepower
to get there.
Does that seem reasonable? 80cc kit, 24mm carb, porting,
pipe - that could feasibly put out the six or seven he'd need.
I imagine that getting it to put out six or seven horses at WOT
would be a tuning challenge, but I know Nate could do it, and
imagine the west coasters can too.
Now, 95 miles per hour would require more than 10 kilowatts,
or more than fifteen horsepower.
Is that possible with a 150cc engine? Definitely. Not the
clone of a 40-year-old Honda design that comes on a Wildfire
scooter, though.
The _best
manufacturer estimate_ of a wildfire scooter, though, says
that it can put out 6.5 kilowatts (about nine horsepower), and
Lifan-engined bikes are notoriously over-rated (literally, not
figuratively - I actually like them quite a bit).
So, no, dude didn't go 95 unless his illegal shixtbox has been
regeared, converted to water cooling, fitted with a bigger carb
and an exhaust trumpet, re-cammed, and run on nitromethane.
Even more in perspective - the same utility says that it will
take about 1.5 horsepower to maintain 45 miles per hour.
That is absolutely correct - an Olympic cyclist can maintain the
1000+ watts needed to do this for a few minutes - and cycling
races regularly get up to the mid-forties in flat sprints.
That's clean horsepower, though, and your two-stroke engine
is not - a 1.5 Maxi doesn't put 1.5 horsepower on the ground
at full throttle, but the people who've tuned them up (above,
bunches of them) can get them to.
I believe 45. High sixties into seventies are plausible for top
of the line setups.
Now show me a ton.
  how fast is your ped?Topic by: sam sam 05/11/08 01:02AM
  Re: how fast is your ped?Re: Zeke Zeke 05/11/08 01:13AM
  Re: how fast is your ped?Re: sam sam 05/11/08 01:20AM
  Re: how fast is your ped?Re: Moped Game Sally Struthers Moped Game Sally Struthers 05/11/08 01:38AM
  Re: how fast is your ped?Re: Veronica Veronica 05/27/08 12:50PM
  Re: how fast is your ped?Re: sam sam 05/11/08 01:45AM
  Re: how fast is your ped?Re: Ben Ben 05/11/08 02:03AM
  Re: how fast is your ped?Re: Raymond Wright IV Raymond Wright IV 05/11/08 10:45AM
  Re: how fast is your ped?Re: Evan Evan 05/11/08 01:46PM
  Re: how fast is your ped?Re: General Jackson General Jackson 05/12/08 03:40PM
  Re: how fast is your ped?Re: Veronica Veronica 05/27/08 12:58PM
  Re: how fast is your ped?Re: Steve Steve 05/11/08 10:53AM
  Re: how fast is your ped?Re: mateo mateo 05/27/08 03:51AM
  Re: how fast is your ped?Re: Freebird Freebird 05/11/08 01:06PM
  Re: how fast is your ped?Re: j j 05/11/08 10:25PM
  Re: how fast is your ped?Re: jake jake 05/11/08 04:24PM
  Re: how fast is your ped?Re: Zeke Zeke 05/11/08 10:27PM
  Re: how fast is your ped?Re: sam sam 05/11/08 05:26PM
  Re: how fast is your ped?Re: Flynnturd Flynnturd 05/11/08 06:09PM
  Re: how fast is your ped?Re: Shane Shane 05/12/08 10:35AM
  Re: how fast is your ped?Re: Austin Austin 05/11/08 06:40PM
  Re: how fast is your ped?Re: sam sam 05/11/08 06:58PM
  Re: how fast is your ped?Re: Graham Motzing Graham Motzing 05/11/08 07:19PM
  Re: how fast is your ped?Re: Zack Zack 05/11/08 09:04PM
  Re: how fast is your ped?Re: sam sam 05/11/08 07:24PM
  Re: how fast is your ped?Re: elliot elliot 05/11/08 08:25PM
  Re: how fast is your ped?Re: Dan T Dan T 05/21/08 11:16PM
  Re: how fast is your ped?Re: sam sam 05/11/08 10:22PM
  Re: how fast is your ped?Re: Freebird Freebird 05/11/08 10:35PM
  Re: how fast is your ped?Re: elliot elliot 05/11/08 10:37PM
  Re: how fast is your ped?Re: 70 mph 50cc 70 mph 50cc 11/08/09 05:13PM
  Re: how fast is your ped?Re: Freebird Freebird 05/11/08 10:42PM
  Re: how fast is your ped?Re: Fred Fred 05/11/08 10:44PM
  Re: how fast is your ped?Re: Fred Fred 05/11/08 10:46PM
  Re: how fast is your ped?Re: j j 05/11/08 11:08PM
  Re: how fast is your ped?Re: Freebird Freebird 05/11/08 10:49PM
  Re: how fast is your ped?Re: Fred Fred 05/11/08 10:58PM
  Re: how fast is your ped?Re: Freebird Freebird 05/11/08 11:05PM
  Re: how fast is your ped?Re: elliot elliot 05/11/08 11:12PM
  Re: how fast is your ped?Re: sam sam 05/11/08 11:12PM
  Re: how fast is your ped?Re: Raymond Wright IV Raymond Wright IV 05/11/08 11:17PM
  Re: how fast is your ped?Re: Freebird Freebird 05/11/08 11:17PM
  Re: how fast is your ped?Re: Elder Bandit Elder Bandit 05/12/08 01:29AM
  Re: how fast is your ped?Re: j j 05/12/08 02:09AM
  Re: how fast is your ped?Re: wild goose wild goose 05/12/08 01:55AM
  Re: how fast is your ped?Re: hipso hipso 05/12/08 11:10AM
  Re: how fast is your ped?Re: sam sam 05/12/08 02:52PM
  Re: how fast is your ped?Re: steve steve 05/25/08 07:34PM
  Re: how fast is your ped?Re: elliot elliot 05/12/08 03:33PM
  Re: how fast is your ped?Re: General Jackson General Jackson 05/12/08 03:41PM
  Re: how fast is your ped?Re: Elder Bandit Elder Bandit 05/12/08 03:46PM
  Re: how fast is your ped?Re: terry dean terry dean 05/12/08 05:34PM
  Re: how fast is your ped?Re: .Allen Schlung .Allen Schlung 05/12/08 05:42PM
  Re: how fast is your ped?Re: Freebird Freebird 05/12/08 06:27PM
  Re: how fast is your ped?Re: .Allen Schlung .Allen Schlung 05/12/08 06:28PM
  Re: how fast is your ped?Re: SAm SAm 05/18/08 07:49PM
  Re: how fast is your ped?Re: Nick Price Nick Price 05/21/08 10:08PM
  Re: how fast is your ped?Re: hondaman hondaman 05/19/08 09:49PM
  Re: how fast is your ped?Re: foxboss9 foxboss9 05/20/08 07:55AM
  Re: how fast is your ped?Re: Mozes Mozes 05/20/08 12:36PM
  Re: how fast is your ped?Re: Erik Elhammer Erik Elhammer 05/21/08 05:23AM
  Re: how fast is your ped?Re: dallas dallas 05/21/08 05:48PM
  Re: how fast is your ped?Re: Zeke Zeke 05/21/08 08:53PM
  Re: how fast is your ped?Re: Joe Scott Joe Scott 05/21/08 10:15PM
  Re: how fast is your ped?Re: Dan T Dan T 05/21/08 10:53PM
  Re: how fast is your ped?Re: mike mike 05/22/08 12:09AM
  Re: how fast is your ped?Re: vic vic 05/22/08 01:24AM
  Re: how fast is your ped?Re: Dan T Dan T 05/22/08 02:35PM
  Re: how fast is your ped?Re: .Allen Schlung .Allen Schlung 05/22/08 03:09PM
  Re: how fast is your ped?Re: BootyClap Ninja BootyClap Ninja 05/22/08 03:41PM
  Re: how fast is your ped?Re: Bort Hoff Bort Hoff 05/22/08 03:47PM
  Re: how slow are my peds?Re: Troy Elizares Troy Elizares 05/22/08 04:31PM
  Re: how slow are my peds?Re: Dan T Dan T 05/22/08 06:37PM
  Re: Whey fast.Re: Troy Elizares Troy Elizares 05/24/08 11:52PM
  Re: how fast is your ped?Re: dave dave 11/08/09 03:57AM
  Re: Whey fast.Re: ✝️TD-THE MORAL AUTHORITY✝️ ✨ ✝️TD-THE MORAL AUTHORITY✝️ ✨ 05/24/08 11:57PM
  Re: Whey fast.Re: Troy Elizares Troy Elizares 05/25/08 12:03AM
  Re: how fast is your ped?Re: Dan Dan 05/25/08 07:36AM
  Re: how fast is your ped?Re: Jim Jim 05/25/08 04:03PM
  Re: how fast is your ped?Re: steve steve 05/25/08 07:35PM
  Re: how fast is your ped?Re: daveysaves daveysaves 05/26/08 02:12AM
  Re: how fast is your ped?Re: MC Bodge MC Bodge 05/27/08 05:27AM
  Re: how fast is your ped?Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 05/27/08 10:21AM
  Re: how fast is your ped?Re: jaker jaker 05/27/08 10:23AM
  Re: how fast is your ped?Re: J W J W 05/27/08 05:03PM
  how fast is your ped?Re: Brennan O. Brennan O. 05/27/08 05:11PM
  Re: how fast is your ped?Re: mmreinha mmreinha 05/27/08 09:43PM
  Re: how fast is your ped?Re: zeke zeke 11/08/09 06:34AM
  Re: how fast is your ped?Re: b b 11/08/09 07:15AM
  Re: how fast is your ped?Re: human drew human drew 11/08/09 10:44AM
  Re: how fast is your ped?Re: Mo Peds Mo Peds 11/08/09 10:47AM
  over itRe: Nate Bandit Nate Bandit 11/08/09 01:21PM
  Re: over itRe: human drew human drew 11/08/09 03:53PM
  Re: how fast is your ped?Re: 70 mph 50cc 70 mph 50cc 11/08/09 05:15PM
  Re: how fast is your ped?Re: sunflower seeds sunflower seeds 11/12/09 03:47PM
  Re: how fast is your ped?Re: GARzan Justin GARzan Justin 11/08/09 06:24PM
  Re: how fast is your ped?Re: dave dave 11/08/09 09:00PM
  Re: how fast is your ped?Re: Fubar Fubar 11/08/09 10:27PM
  Re: how fast is your ped?Re: mattology - mattology - 11/08/09 10:19PM
  Re: how fast is your ped?Re: x d x d 11/09/09 01:47AM
  Re: how fast is your ped?Re: pullstart pullstart 11/09/09 12:10PM
  Re: how fast is your ped?Re: andrewhed andrewhed 11/09/09 12:27PM
  Re: how fast is your ped?Re: andrewhed andrewhed 11/09/09 09:45PM
  Re: how fast is your ped?Re: . . . . 11/09/09 10:10PM
  Re: how fast is your ped?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 11/10/09 04:59AM
  Re: how fast is your ped?Re: Nash . Nash . 11/10/09 05:09AM
  Re: how fast is your ped?Re: Andy Zeros Andy Zeros 11/10/09 12:14PM
  Re: how fast is your ped?Re: terry dean terry dean 11/11/09 03:27PM
  Re: how fast is your ped?Re: Lance Campeau Lance Campeau 11/11/09 05:19PM
  Re: how fast is your ped?Re: terry dean terry dean 11/11/09 09:00PM
  Re: how fast is your ped?Re: johno roberts johno roberts 11/11/09 10:21PM
  Re: how fast is your ped?Re: sTv sTv 11/11/09 10:33PM
  Re: how fast is your ped?Re: terry dean terry dean 11/12/09 12:03AM
  Re: how fast is your ped?Re: human drew human drew 11/12/09 10:23AM
  Re: how fast is your ped?Re: doppelkolben doppelkolben 11/12/09 05:14PM
  Re: how fast is your ped?Re: mark Kloninger mark Kloninger 11/12/09 10:19PM
  Re: how fast is your ped?Re: Andy Zeros Andy Zeros 11/12/09 11:29PM
  Re: how fast is your ped?Re: Nash . Nash . 11/13/09 12:57AM
  Re: how fast is your ped?Re: Eat A Cactus Eat A Cactus 11/13/09 12:56PM
  Re: how fast is your ped?Re: Sam Blk Sam Blk 11/13/09 02:06PM
  Re: how fast is your ped?Re: Burke S Burke S 11/13/09 10:27PM
  Re: how fast is your ped?Re: Bill_o_MAtic Bill_o_MAtic 11/14/09 08:21PM
