does anyone have one?
will i need a relay?
are they really 133dB?
its coming on monday i can't wait!!!
anyone?
fuck that, airzounds air horn. 115+ Db and no wiring needed.
that looks like shit though. a soda bottle with air and a horn on the bars. this goes right were the old horn was and you can use it unlimited with out pumping it up like the airzound. this one you just unplug old horn, unbolt it, bolt up stebel and plug it in.
and it was only $35
again, fuck that lol
no dice for a 6v system, and how many amps does it draw vs how many amps does your mag produce?
i have a 12v system
and say what?
how many amps does your magneto generate, how many amps does the horn draw, and how many amps does your lighting/ignition system draw? i know the tomos has a battery which will buffer a high amperage draw, but pulling alot of amps from a small system still isnt good.
yeah uh... all i know is it doesnt have a battery and when i revv it more watts or volts are generated because the lights get brighter and the horn louder
are you recommending a relay?
anyone?
looks like it pulls 10-12 amps. how many watts is the system its going to be put on?
how can i find out?
It should be fine. You run a horn intermittenly. If you want to put your system to a test lay on that horn for a couple minutes.
if it fails what happens?
bump
