Re: over heating puch
Smoking Bear /
my setup:
polini 64cc kit
bing 14mm
leovinci pipe
B6HS plug
78 jet (using kit straight outta the box)
I sanded the mating surfaces of the cylinder and head to get rid of the high points, which raised my compression by less than 10psi, and my jet size dropped to a 68. It's amazing how warped they were when I got them.
Also, the bing 14 doesn't cover the full range from idle to WOT very well.you either have to jet for top speed (which will be way too rich at idle, and you'll have to shut the bike off at lights and such) or for daily in-city use, which will be too lean at WOT. I jet for daily use, rather than racing speeds, and can cruise at 40 and top out at 45 before overheating.
  over heating puchTopic by: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/10/08 01:55AM
  Re: over heating puchRe: Responsible Jon Responsible Jon 05/10/08 11:32AM
  Re: over heating puchRe: jack jack 05/10/08 11:38AM
  Re: over heating puchRe: Bitter Bitter 05/10/08 01:59PM
  over heating puchRe: Brennan O. Brennan O. 05/10/08 01:06PM
  Re: over heating puchRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/10/08 02:22PM
  Re: over heating puchRe: Josh G Josh G 05/10/08 02:35PM
  Re: over heating puchRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/10/08 02:44PM
  Re: over heating puchRe: Smoking Bear Smoking Bear 05/10/08 04:02PM
  Re: over heating puchRe: Smoking Bear Smoking Bear 05/10/08 04:20PM
  Re: over heating puchRe: elliot elliot 05/10/08 05:10PM
  Re: over heating puchRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/11/08 03:22PM
  Re: over heating puchRe: weeder weeder 05/12/08 11:51AM
  Re: over heating puchRe: leedogcretard leedogcretard 05/12/08 07:03PM
  Re: over heating puchRe: weeder weeder 05/13/08 09:35AM
  Re: over heating puchRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/13/08 11:55AM
  Re: over heating puchRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/13/08 11:56AM
  Re: over heating puchRe: elliot elliot 05/13/08 04:03PM
  Re: over heating puchRe: OGLEE OGLEE 05/13/08 04:33PM
  Re: over heating puchRe: lee lee 05/14/08 12:15AM
  Re: over heating puchRe: weeder weeder 05/14/08 10:13AM
  Re: over heating puchRe: willie willie 05/14/08 09:40PM
  Re: over heating puchRe: Graham Motzing Graham Motzing 05/15/08 12:20AM
  Re: over heating puchRe: Smoking Bear Smoking Bear 05/15/08 12:59PM
