Re: 65 Metra Kit
it's probably because your throttle cable wasn't long enough to let the thing close all the way. to install the kit, you case match (or don't), then you unscrew the head bolts, pop off the head and the cylinder, undo the circlips and knock out (gently!) the wrist pin, pop off the piston, pop the metrakit piston on (put it on the right way up!), put the wristpin in, put the circlips in with circlip pliers/needle nose, align the rings with their guide posts, grease everything up with a little oil, slide the metrakit cylinder on over the rings (put it on the right way up!), slide the head on, redo the bolts to 15 foot pounds (or do it by hand like all these fools do).
  65 Metra KitTopic by: Marcus Marcus 05/07/08 12:01AM
  Re: 65 Metra KitRe: Brennan O. Brennan O. 05/07/08 12:06AM
  Re: 65 Metra KitRe: Marcus Marcus 05/07/08 01:28PM
  Re: 65 Metra KitRe: j j 05/07/08 01:34PM
  Re: 65 Metra KitRe: Brennan O. Brennan O. 05/07/08 01:36PM
  Re: 65 Metra KitRe: Marcus Marcus 05/07/08 01:44PM
  Re: 65 Metra KitRe: j j 05/07/08 02:54PM
  Re: 65 Metra KitRe: Flagrant - Flagrant - 05/07/08 01:52PM
  Re: 65 Metra KitRe: Marcus Marcus 05/07/08 05:29PM
  Re: 65 Metra KitRe: j j 05/08/08 02:46AM
  Re: 65 Metra KitRe: David Ciao David Ciao 05/07/08 07:01PM
  Re: 65 Metra KitRe: j j 05/08/08 02:45AM
  Re: 65 Metra KitRe: Aris Dimalanta Aris Dimalanta 05/07/08 07:14PM
  Re: 65 Metra KitRe: Marcus Marcus 05/08/08 01:52AM
  Re: 65 Metra KitRe: Marcus Marcus 05/08/08 10:48AM
  Re: 65 Metra KitRe: hipsy hipsy 05/08/08 11:32AM
  Re: 65 Metra KitRe: Marcus Marcus 05/08/08 11:53AM
  Re: 65 Metra KitRe: buckswilde buckswilde 05/08/08 02:53PM
  Re: 65 Metra KitRe: Marcus Marcus 05/08/08 05:27PM
  Re: 65 Metra KitRe: j j 05/08/08 05:39PM
  Re: 65 Metra KitRe: Fred Fred 05/08/08 05:39PM
  Re: 65 Metra KitRe: buckswilde buckswilde 05/09/08 05:20PM
  Re: 65 Metra KitRe: j j 05/09/08 06:29PM
  Re: 65 Metra KitRe: Marcus Marcus 05/08/08 05:53PM
  Re: 65 Metra KitRe: Andy Andy 05/08/08 06:04PM
  Re: 65 Metra KitRe: j j 05/08/08 06:54PM
  Re: 65 Metra KitRe: hipsy hipsy 05/08/08 06:06PM
  Re: 65 Metra KitRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/08/08 07:34PM
  Re: 65 Metra KitRe: Marcus Marcus 05/08/08 08:01PM
  Re: 65 Metra KitRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/08/08 09:17PM
  Re: 65 Metra KitRe: Marcus Marcus 05/09/08 03:05AM
  Re: 65 Metra KitRe: Marcus Marcus 05/09/08 06:59AM
  Re: 65 Metra KitRe: Fred Fred 05/09/08 08:21AM
  Re: 65 Metra KitRe: Moonshiner Moonshiner 05/09/08 10:05AM
  Re: 65 Metra KitRe: David Ciao David Ciao 05/09/08 01:27PM
  Re: 65 Metra KitRe: Marcus Marcus 05/09/08 01:38PM
  Re: 65 Metra KitRe: David Ciao David Ciao 05/09/08 01:43PM
  Re: 65 Metra KitRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/09/08 02:13PM
  Re: 65 Metra KitRe: Marcus Marcus 05/09/08 02:59PM
  Re: 65 Metra KitRe: Fred Fred 05/09/08 11:24PM
  Re: 65 Metra KitRe: buckswilde buckswilde 05/09/08 11:42PM
  Re: 65 Metra KitRe: Fred Fred 05/09/08 11:44PM
  Re: 65 Metra KitRe: buckswilde buckswilde 05/09/08 11:58PM
  Re: 65 Metra KitRe: Marcus Marcus 05/10/08 04:20AM
  Re: 65 Metra KitRe: David Ciao David Ciao 05/10/08 11:20AM
  Re: 65 Metra KitRe: Marcus Marcus 05/10/08 01:13PM
  Re: 65 Metra KitRe: David Ciao David Ciao 05/10/08 05:45PM
  Re: 65 Metra KitRe: j j 05/10/08 08:21PM
  Re: 65 Metra KitRe: David Ciao David Ciao 05/10/08 09:59PM
  Re: 65 Metra KitRe: Marcus Marcus 05/11/08 02:52AM
