Right now my moped only goes 26 maybe 30 on a real good day but i am tired of it going slow and i want it to go at least to 35-40.
performance intake and exhaust, as well as a larger carb jet.
Also the stock gearing on the streetmate R will limit your speed. Me and my roomate have been tweaking a 08 R for a few weeks now. Right now its hitting high 30's with just a bi-turbo, uni intake, and larger carb jet. Gears and airsal kit are sitting at home waiting to be installed!
nitrous
make it look fast it goes slow
make it look slow it goes fine
I can't believe the Streetmate R only goes about 26mph.
F-f-f-fail
there is about 4 or 5 posts up on the performance section RIGHT NOW about this....just do your share of research!
ghost riding
I have 2008 Streetmate R with A55 Airsal Kit, Techingas Next R Exhaust, Intake Mod like Ike at Ike's Bikes developed, 22 tooth sprocket and a 58 jet. I just finished it and have road twice less than a mile. It is slightly down hill and half throttle for break in and pegs the speedo. This is out of the box with no tuning. I copied this setup from Ike so there should not be a lot of adjusting other than maybe another jet. It helps that I am 130 lbs. Hope this helps.
what kind of carb do you have on your a55 airsal kit setup?
The stock 14 PVHA but with bigger jet and modified air box.
the "how do I make my brand new tomos go fast" post will never die...
My streetmate R goes 40+...I have a biturbo, uni, carb jetting/tuning, and the 22 rear sprocket...
Honestly, beyond a nice pipe, a bigger jet and maybe a sprocket, I wouldn't fuck too much with it. Mods on a bike are a good way to cut down on its reliability. I have a newer tomos I gave those mods too, and its plenty fast for in the city, 40-42 or faster if i tuck. If you want to mod a bike buy an old puch or something that wont cost you 1000+ if it bursts into flames or a wheel falls off at 50mph. Just my opinion.
hey ya'll im opening up an old post and i just had one question along the lines of jetting all im doing is a biturbo or tenchnigas next , uni, carb jetting/tuning, and the 22 rear sprocket but what size jet should i move up to to correspond well with the uni pod filter? What size jet do ya'll reccomend? thanks
Kyle- Back on the PED
60
much thanks.
