I took my 12mm out to around 15mm using a drill bit. I put the carb in a clamp and lined it up and drilled right on through. I think I used a 9/16" or a 5/8" drill bit. Make sure you take EVERYTHING out of the carb body and take it slow. Let the weight of the drill do the work and you'll be ok.
