Re: getting a seized metrakit overbored
Silverfox Sullivan /
No, do not buy the piston first as you do not know how far the machine shop will have to go to clean up the cylinder.
Just give the shop the sizes of the oversize pistons and they will stop at the smallest diameter that will clean the cylinder. Then buy the correct piston.
If Metra has a standard piston to cylinder wall clearance spec, give that to the machine shop. Otherwise the machinist will have to use his best judgement/experience in the matter.
FYI, the Honda Hobbit manual says that the stock clearance is:.050-.025mm max .150mm
  getting a seized metrakit overboredTopic by: j j 05/05/08 01:48AM
  Re: getting a seized metrakit overboredRe: Greg Greg 05/05/08 03:52AM
  Re: getting a seized metrakit overboredRe: geners b geners b 05/05/08 04:24AM
  getting a seized metrakit overboredRe: Brennan O. Brennan O. 05/05/08 10:26AM
  Re: getting a seized metrakit overboredRe: Los Los 05/05/08 10:49AM
  Re: getting a seized metrakit overboredRe: Silverfox Sullivan Silverfox Sullivan 05/05/08 02:47PM
  Re: getting a seized metrakit overboredRe: Bort Hoff Bort Hoff 05/05/08 02:50PM
  Re: getting a seized metrakit overboredRe: j j 05/05/08 03:56PM
  Re: getting a seized metrakit overboredRe: geners b geners b 05/05/08 04:55PM
  Re: getting a seized metrakit overboredRe: Bort Hoff Bort Hoff 05/05/08 05:40PM
  Re: getting a seized metrakit overboredRe: Greg Greg 05/05/08 06:06PM
  Re: getting a seized metrakit overboredRe: geners b geners b 05/05/08 08:39PM
  Re: getting a seized metrakit overboredRe: Bort Hoff Bort Hoff 05/05/08 09:46PM
  Re: getting a seized metrakit overboredRe: Chris Paz Chris Paz 05/05/08 10:02PM
  Re: getting a seized metrakit overboredRe: j j 05/05/08 10:11PM
  Re: getting a seized metrakit overboredRe: Brennan O. Brennan O. 05/05/08 10:17PM
  Re: getting a seized metrakit overboredRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 05/06/08 02:14AM
  Re: getting a seized metrakit overboredRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/06/08 02:30AM
  Re: getting a seized metrakit overboredRe: Greg Greg 05/06/08 03:01AM
  Re: getting a seized metrakit overboredRe: Speedbird Speedbird 05/06/08 06:03AM
  Re: getting a seized metrakit overboredRe: j j 05/06/08 06:22AM
